Hello,
I want to get the opinions and advice of the forum as to what should be done do to rectify what I think is a problem electrical situation.
Our house was extended in 1980 and it looks like a rough job. I am intending to insulate the ceiling (flat roof) so pulled the plasterboard down to expose the joists...
What I am seeing is the ring main running in the ceiling through the joists. It is also running to/through the base of the two light sockets. In each case a T&E spur is running off to the associated light switch.
I have confirmed it is the ring main by seeing what else isn't available when its 32A MCB is tripped.
My questions:
How good/bad/otherwise is it that lights are being powered through the ring main in this way?
If bad, then what should be done to rectify it?
I am not intending to do the work myself, but would like to understand what I should be asking a sparky to do - and maybe why.
Any comment would be appreciated.
My questions:
