Hello
I have a potterton puma 80e, its about 9yrs old and it is giving me problems. The Led (LSP) on the front panel, 3rd light up, was shows red and I cannot not get any hot water or heat.
I have read past messages of other Pott owners and i think i've got a fault the same as others who have a puma 80e. Its saying low pressure but the pressure gauge is at a steady 1Bar and there's no leaks. I've carried out a couple of simple things to see if i can put it right.
1. cleaned out crud from the pressure switch and valve port. Forced water under slight pressure, by mouth through a tube, through the pump drain-off and water spouted out the pressure switch port, also reversed that action = No blockage
2. tested pressure switch's continuity = OK
3. scanned the back of the Mod PCB through a powerful magnifying glass
= No dry joints
What do you make of this, i disconnected one of the yellow wires from the W.P.Switch and the boiler came on, heat and hot water on demand if i pushed the on button, i didn't let it run too long. But the sheer pleasure of a heated room. I'm tempted!!!
What is the problem?
I'm making this appeal because i can't afford to go to a big name repairer and i don't employ cowboys. The heating engineer who fitted the system has not returned my two messages left on his machine. So help if you can
Thanx in advance
= No dry joints
Thanx in advance
