A gas boiler can explode,
When there is an alternative, that costs no more, you install the failsafe system. It is that simple. Anyone who does not is irresponsible and should get out of the industry.
No death is acceptable. Two wrongs do not make a right!
It is quite low I know that.
I like combis in externally fitted cabinets. Very safe!!!!
Being as you only talk the talk (apart from when you w*** the w*** to waterblast), you'll not have noticed that combi theft has been rife for years which might compromise your safety claim. Unless of course you know of any of the light fingered brigade who cap off and soundness test before they scarper.
frankly if everyone hit the ignore button all his posts disappear
I know
I agree, so a unvented cylinder fitted correctly with all the safety device installed where they should be is perfectly safe.
It does seem Dr that you really making your own arguement?
For what I can tell you are saying
1. No unvented cylinder is safe, no matter how well it has been installed its only a matter of time till it explodes.
2 All Heat stores are safe. If it has been installed really poorly it will not present a danger to a member of the public.
3 since the terrible incident ALL open vented cylinders and ALL Plastic cold water storage cisterns are dangerous and WILL over heat resulting in terrible property damage or death.
4 All combis are safe as long as they are installed in a outhouse type situation
Is that about the gist of it Dr??
