You may have to measure the resistance of the windings, between each other, if it is a delta, if there are 3 sets of seperate windings witha 4th common connection then measure each windings resistance against the common connection,
There should be same reading between all three sets of windings, for example if you have 3 terminals let us call them A, B, C, and they are in a delta configuration, that means they do not have a 4th common connection,
so measure resistnace as betwen :
A&B
A&C
B&C
They should all be the same and if they differe then you have a likely problem with the windings, they can be short circuit as well as open circuit windings, it is likely yours have gone open or elose you would be seeing lot of smoke from it if it was shorted out one of the windings.
