need help to set up texecom Comip in 24w panel
10 Jan 2014
Kent
Can someone please guide me on how to set up com ip using keypad. I have fully functional system with gsmcom.
An engineer that set it up all did not know how to do it so i ended up with half functioning system
thank for your help
What do you want to use it for are you free now?
Engineering
got to com port setup
select comp-ip
if its on com1 thats all that needs doing, if its on com2 you will need to adjust the digi speed of the com.
To use the app/ upload download via wintex you need to do a few other things.
Who is your internet provider, what router/modem do you have as you will need to do port forwarding?
