Have I given any ill equipped advise?
If you had indeed given anything at all then it would have been "advice".
"Advise" is the verb!
This English Literature is so complicated isn't it. Just as well that I stick to engineering!
I can't see much of an issue, regarding the operation of his boiler, the flue terminal still has plenty of space to breath and discharge and disperse fumes, I can assure you his boiler simply did not stop because of your porch has been erected too near his terminal, it is not too near from operational point of view, but too close from safety point of view. His flue would have to be almost touching your wall before it becomes an issue to the correct operation of your boiler or it stops working as it cannot breath oxygen in!
also to give out general advise where I feel I can contribute, in number of different subjects, never have I given any bad advise or broken any forum rules.
English Literature
hot air is lighter as it is less dense, so it tends to rise. and disperse.
English Literature
Actually I already hold an honours degree in it.
Your OPINION is as about as useful and relevant as condom in a nunnery.
I really sometimes wonder if you guys have really earned all those ''thanked count'' through your own shear hard work, or do you just go around patting each other!
