OK got the 10mm cable and a new CU with matching MCB plus a new 2pole switch do I use the 40amp or 50amp mcb? that is the question and before i put it all in can I wack the mcb into the old CU with the 6mm cable just so,s I can have a shower as I'm staRTING TO STINK!
