Hi, I hope someone can help as my gas engineer is lost for an explanation. I have just has a new gas boiler fitted in place of my old baxi. The new one is a Vaillant 428 heat only boiler, the system has now also been changed from open vent to a sealed system. I have a magnaclean installed too. Old hot water cylinder was reused.
Problem: when heating water only the boiler will sometimes fire up for around 5 mins before switching off and cooling down, then it will begin a cycle of firing for anything from ONLY 6 seconds to 60 seconds, going off for its 2 min cooling off everytime. All this when the temp in the tank is tepid, This cant be normal, it is taking anything from 1 hour plus to heat a tank of water as it spends twice as much time off, than on. My engineer is lost for an explanation, the only one he has is that as the tank is close to the boiler and the return run is quite short, the water hasn't had a chance to cool off before returning to the boiler. The boiler sensing that the water is more or less the same temp both ends switches off!
The magaclean is fitted to the return side as is the expantion vessel. Its on 1 bar. Boiler performs more or less as I would expect when the heating is on, switching off when the rads are hot. Sometimes it just runs for 10-20 seconds, other days for 5 mins.
Vaillant help line do not want to know as we have not got vaillant cylinder!!
All vaillant helpline offered was "to turn down a valve on the flow side to restrict flow". We did this and the bolier was shutting off after 5 seconds everytime!
Is this a flow restriction problem, air lock, location of the explantion vessel, old tank or have I got a duff boiler or is that how they work.
Any help please
Rick
Any help please
Rick
