No. It's cable. I only just now learned the diff between flex and cable.ban-all-sheds said:2) It appears that it is wired with flex, not cable..
Per my answer above, I have actually purchased Pirelli 2.5mm(squared) solid twin & earth cable.ban-all-sheds said:3) You appear to be wiring new sockets with 25mm flex, not 2.5mm cable.
That's why I'm here.ban-all-sheds said:4) You don't know what you are doing
jgreer said:Now, should I be concerned? Has anyone else seen this?
breezer said:the existing twin and no earth, can you see the colour of the cores? are they silver and stranded?
mapj1 said:2) read the resistance between the earth pins of any pair of sockets, and/or each socket earth and the main earth bar at the consumer unit.
If the resistance is similarly low, then you do have an earth really, and when you extend the system, you need to pick up the existing earth, and continue it.
John Watson Electrical Services said:PME Protective Multiple Earthing - commonly used in this area for new buildings. Only the Live and Neutral (or to be precise the PEN conductor) conductors enter the building, and the Neutral and Earth are joined just after they enter the building. Inside the building they are separate. This gives faster blowing of fuses etc. in event of a fault - but is not entirely without its drawbacks.
PEN means a conductor combining the functions of both earth and neutral.
