OK then assuming the brown wire in 'C' is correct, you will need to:
1. Move the blue wire in terminal 1 of the cylinder thermostat to terminal 2, and then;
2. Somehow wire terminal 1 on the cylinder thermostat to the switched live on the boiler. It's not good practice to use the earth wire as a live, so I'm not going to suggest that, although many installers do it.
Of course there is also the possibility that if someone incompetent has been tinkering with the wiring there may be problems elsewhere.
