Hi. 1992 house. Myson SD63 pump at '3' setting. 4 bed house 16 radiators some double.
The pump has always been louder than our last house and is now really noisy especially when it first comes on. It sounds like it's on it's legs. I turned the setting down to level 2 which has helped.
I was thinking of replacing it myself since there are valves either side, ...might not be a big job, until I started reading up on pumps and comments from your members. The Grundfos website showed pictures on how it should be on an upright pipe, flow upwards and if it has to be horizontal the motor spindle should not be upright.
http://img337.imageshack.us/img337/1477/pumphd5.jpg[/IMG][/url]
Everything mine isn't !
The wall the pipe is up against is only plaster board into a dressing room so I can knock a hole through and with a small box the otherside it won't be noticed behind all the shoe boxes.
The SD63 Myson pump looks like a standard size but was it ever big enough ? Is it worth getting the pump horizontal for noise reduction and less wear and tear ?
Would a Grunphos 15/60 be a better less noisy pump?
Am I missing anything obvious please, or should I just get professional help do you think ?
