Noisy cold water tap
22 Jan 2007
London
My coldwater tap in my upstairs basin makes a lot of noise when I start to turn it on (a sort of wailing sound). Once fully open it is fine but then when it is turned of it it makes a banging sound (like water hammer). Last week the cold water supply to this tap burst when I turned it off. I have since fitted a new flexible tap connector but noises continue.
The tap is supplied direct from the mains.
Any ideas what could be causing this?
Many thanks
Nick
Probably just loose washer/jumper in tap. Change washer first and see if it helps.
Thanks,
How do I reduce the pressure when the tap is being fed direct from the mains?
