Would you please explain the benefits.
Unfortunately you don't tell us anything about the size or type of system.
To answer the question, Yes you should be ably to mix and match, provided the installer knows what he's doing, without any problems.
Thanks for the question, doitall. You made me think. Which is usually a good thing. Here's the system:
It's an old semi. Narrow with very tall rooms. I have 10 radiators and a towel rail. The boiler's in the cellar. There's a single attic room with one radiator, 4 plus towel rail on the 1st floor and 5 on the ground floor. The boiler is old and expensive to run and maintain. That's why I'm getting it replaced. I'm also getting TRV's fitted on most of the rads. It's an open vented system.
When the boiler fires up the first radiators in the loop get hot fast and the last ones take half an hour or so to get hot - although once they get hot they're fine. I believe that one benefit of the 2-pipe system is that you don't get this problem of some radiators heating up much faster than others.
The plumber told me that modern "efficient" boilers work more "efficiently" with a 2-pipe system. Although I must say I thought that they use the temperature difference between the outward and return flow, and with a one-pipe system I would expect that difference to be greater, so wouldn't they be more efficient in a one-pipe set up?
I've discussed zoning by converting the pipework to "S plan plus" (??) and having separate controls for ground and first floors. This seems like a good idea because the radiators would heat up much faster using only one zone and also we wouldn't be sending hot water all round the house when we don't need to.
Most people recommend converting the whole house to 2-pipe. But that's not practical at the moment because I would have to replace some tiled floors. However, I have been recommended to convert some rads to 2-pipe where that is practical and I'm unsure about that. Not least because of the difficulty with balancing the system - especially where the use of TRVs is going to cause the load to change over time and I don't know if it will still be in balance when the load changes if some of the rads are on 2-pipe and some on a single pipe.
Anyhow. Any thoughts or experience with a mixed system would be very welcome.
Tom
