Old wiring colours - is this English?
24 Jun 2004
I've got a very old electric blender that I used for a couple of years with no problem, then forgot about. I've just got it out to use but we must have used the plug for something else.
There are 2 wires: one black and one blue. The lable shows the earthy symbol (2 concentric squares) so there is no earth wire. It says 250v 100w, Type M100.
Which is live and which is neutral?! It says on this website the old colours are Red, Black and Green, so I'm confused.
If this is meant to be on "electrics outside UK" I apologise!
Many thanks :confused:
my comments are in your other thread on this
This was probably made for the German market originally. If so Black is live, Blue is nuetral, and if there is single pole switching inside it will be the black lead.
However, as the other response notes, its not that much of an issue, as the continental systems do not guarantee L-N polarity. Just unplug it when not in use -but you'd do that anyway I hope! :)
The other give away is if it says '220V' rather than 240 - that is the old continental voltage (of course we are all 230 now, but nothing has really changed, except on paper.) Select a fuse based on the wattage, allowing a bit for motor inrush, and check it carefully before plugging it in for damage to the cable or casing,
Rememeber 10 times as many accidents are with portable appliences and flexes, rather than fixed wiring.
Thanks very much MapJ. I didn't realise I had posted this twice! I won't be using it, I was going to give it to a friend, so I'll warn them aswell.
Thank you! :D
