Hi Neewbie here.
Trying to systematically resolve the wiring nightmares of previous owner. Latest one.
30Amp feed from CU goes to outside light, then via junction box then goes off the a plug socket in garage. For the time being this has been disconnected.
Two approaches I was considering.
1. Feed from garage lighting circuit. into Single gang RCB with 5 amp fuse then into wall mounting external light.
2. Take original 30 CU feed. into Single gang RCB with 5 amp fuse and then into external sensor light.
I want to make sure its safe and the correct approach. Please advise if other methods are recommended.
thanks
thanks
