Thats right. We were worried you'd try to connect to the bottom screw of the MCB as well, which is the supply before the MCB protection, this would be a a very dangerous fault, there is a picture on here with a consumer unit connected up as such!
Though you should be aware of the following:
- The incomming tails to the main isolator will be live all the time when when the main isolator is off, some older boards have limited shrouding around terminals. Risks involve catching them with your hands when routing cables, or catching them with a unsheathed earth conductor or any other bit of metal and causing a big bang, loss of power and quite likely burns and arc-eye
- If your board is a split load board you will have two neutral bars
- The neutral and earth of the branch should share the same terminals as the neutral and earth of the existing light circuit
- If any cable is chopped in wall less than 50mm, RCD protection will be required
- If the consumer unit is neat inside, try and bend yours in to match the existing, rather than lashing it in anyhow
- If the cabling is run outside at all other than straight through the wall and into the back of the fitting, then it becomes part P notifiable, the same happens if the inside cabling is in the kitchen. (is the fitting ON the porch, or within the porch?)
