I have just had a new hall carpet fitted but the fitters had to take off the door to the toliet room.
I want to change all the internal doors anyway (they are currently totally flat and a dark wood effect) and I would like to change them to modern white 6 pannel doors that you'd might find in a new-build home.
However, I am having a problem finding doors that fit.
What I need is a couple that are w626mm x h2032mm then to reduce the height to fit.
I can find doors that are 626mm wide and I can find doors that are 2032mm high but no smooth 6 panel doors that have the right width and height.
Is anyone able to advise as I am stuck?
