Hi all ,first post and great site.
I have a 240 eco combi approx 10 yrs old.
Last serviced approx 6 yr ago.
The fault it has developed is that if you run a bath or shower the hot water will run cold after approx 10 mins (this varies thou sometimes 5 or 15 mins)then fluctuate between hot and cold .
I have left the shower running and watched the boiler to see what is happening.
I saw that the boiler was working normally then the main burner would shut off and the amber neon light would come on for approx 10 secs then go out and the main burner would light up.this cycle would then go on every 2 - 3 mins.
I have checked the diverter assy and both plungers and microswitches are working fine.
I have aslo had the dhw temp sensor replaced ( next to the sec heat exchanger).
The central heating system of the boiler works fine.
Any help or comments will really be appreciated.
