power shower
2 Feb 2007
Birmingham
thanks to box basher for reply on tanks, couple of concerns about supply take off points if tanks in tandem and take cold feed in airing cupboard will this not effect the head pressure supplying the hot tank? and as the tee off for the vent pipe is 600mm away from top of hot tank what will stop the pump from drawing water from both sides of the tee connection? have read about essex or warix valve but can't see how this will work.p.s don't want to cut into hot tank for feed.
What do you mean when you use these words?
...and as the tee off for the vent pipe is 600mm away from top of hot tank what will stop the pump from drawing water from both sides of the tee connection?
Lady Luck?
They work because they take water from a place where air cannot be.
That rules out the Essex flange, which happens to be the easiest to fit.
