problem with a halstead best 40
29 Dec 2007
I've just registered and need a little help with my best 40.
It won't start.the book says look for 1vdc or 10vdc at terminal 1 on the ignition controler. I have 1vdc but when it tries to start i get a reading of 10 volts, then it goes back to 1 vdc. I don't know whether to replace the aquastat pcb or the ignition device.
Any suggestions?
The few of these that I have been to have all had the ignition pcb faulty.
Are the MI's not more specific in their fault finding?
Fitted Ignition PCB to one of these recently, - exactly same symptoms as described. Strange thing was, when I started the boiler it ran for 5 secs, then cut out, with the re-set light on the (new) ign pcb box coming on. It would not then re-set, no matter what I did. - As it was late on, I called back in the morning, and tried again - It re-set immediately, and works perfectly now. Strange.
If it helps, the one described here, would not run the fan either, until the Ign PCB was changed.
You do have to turn the boiler stat knob full up before they'll reset.
Thanks for your replys. I have had to wait for the suppliers to open before I can get any parts. So tommorrow I will order an ignition device. I'll let you know when i've fitted it
