Puma 80e Lockout! Spark, but no flame...
27 Sep 2013
Hi, I have a Puma 80e, that started showing the lockout light after it receiving a hot water demand from either hit tap or CH. After investigation, I can see the water pressure is fine, the fan starts, and there are ignition sparks - but they don't catch flame and the lockout comes on. Is there a simple fix for this? The guide on the back of the casing says to check the GV1 and GV2 solenoids.
I've tried the manual's suggestion of "holding reset for 10 seconds" but that doesn't solve the problem.
No dripping taps, no leaks that I'm aware of.
Hope you can help!
You could check the solenoid resistances as you have read.
However, we don't give advice here on gas/combustion issues.
The only advice is to get a competent gas registered engineer who is familiar with these boilers. They are getting a little old now and are slightly different in their design.
Tony
Thanks! Do you know where can I find the solenoids mentioned?
Have a read of this:
Tony
Thanks, I can take a hint!
Let a professional do it before things start exploding...
The makers put that guidance on the inside of the cover for engineer's use! They don't expect the user to be opening the boiler.
Whilst we can give advice on other aspects of the boiler operation anything connected with the gas/combustion/safety devices is not allowed under the forum rules ( which you are deemed to have read and agreed to! ).
Tony
