Bit of a borderline subject here.. but i have a wire i want to trunk around a room.. i had it in mind to use the white pvc pipe that plumbers use, but found
the local merchants didnt have all the fittings to go with it i needed. I thought i'd seen a lot more in office use. I've since found such fittings online, but need to verify.. will that pipeing go with these fittings? Is that pipe 20mm? I can order the fitings individually online but dont want a 30 pack of 3mpipes!
The fittings are here.. i'd be using the rounded conduit boxes to bring it in one wall and out the other.. and the saddle bar spacers to affix to wall. Compatible with pipe from local plumbing merchants?
http://www.toolstation.com/index.html?code=42582
