rad not fully refilling
17 Sep 2005
Leeds
I am trying to re-fit a rad after decorating and it is at lowest part of system as it has system bleed valve on one pipe. It only refills about a quarter of the rad and no hissing from bleed valve. I have turned off all other rads and tried turning on pump but nothing happens. It has a TRV on it but this seems OK. Any ideas ? :?:
Is it a sealed system or an open one (.e. is there an open tank feeding heating system)?
It is a gravity fed system with an open tank.hot water cylinder and back boiler behind a gas fire.
Are you sure air vent on rad is not blocked? If OK, disconnect rad valves from rad and check that each will deliver free flow when opened.
The tank is full. First rad went on OK but not this. I will take it off again and check the flow of water through it....cheers
It was a blocked bleed valve. Thanks for the advice. Next time I will try the easy things first instead of looking for big faults.
