Hi
Got a slight issue.
I have an RCBO for the Smoke Alarms on a 17th Edition CU.
As the CU has two Neutral bars, the Smoke alarm RCBO was connected to the first neutral bar same as the first RCD set.
The issue is as soon as you switch on the power it trips the RCD, which makes sense due to the imbalance
Is it possible to have or purchase another Neutral bar for a Wylex consumer unit so that another bar can be added for any RCBOs before the RCD.
I have about 4 RCBOs before the RCD.
Got a slight issue.
