Recently installed a Premier Elite 24 system in my home. Had few problems but I cannot find out how to switch the 'reset after alarm' to user instead of engineer reset Can anyone help?
10 - Alarms Eng Reset
Each area can be programmed for Engineer or User reset following an Intruder alarm. Areas Assigned to ‘Alarms Eng Reset’ will respond as follows:
• The assigned areas can only be reset using an Engineer code
If ‘Anti-code Reset’ is enabled (option 14) the assigned areas can also be reset using the Anti-code
Areas not assigned to ‘Alarms Eng Reset’ can be reset with any User code that is valid for those areas.
I have the manual and have scanned that and note the references from Paul, but I can't find out how to change to User Reset from Engineer reset. I've gone through the menus but can't find the screen to change the setting.
