how physically big would the equivalent concentric cable be
If I recall about 15mm diameter. Though if the existing is in fair condition they'll more than likely just reclip it
Although he does say this is a TP supply...
Indeed - the clue is in the four singlesAlthough he does say this is a TP supply...If I recall about 15mm diameter. Though if the existing is in fair condition they'll more than likely just reclip it
I'm quite impressed. The man from the DNO appeared within a few hours of me calling them, and reclipped the cables (metal ladder and no PPE!).Defiantly leave it to the dno. The insulation could be cracked or deuterating, you grab hold to put a new cleat on and the next thing you are laying draped across that bird feeder.
replace the cable with 4 twisted singles (that's actually what comes from the pole to the buiding at present), not straight con, which rather surprised me.
I see. It will be interesting to see what they turn up with if/when they come to do 'the proper job'. Given that the main idea seemed to be 'to make it look neater', I'm not sure that this liquorice-like stuff would be too pleasing to the eye if clipped to a wall, even if it were 'double-insulated' and hence 'allowed'.Surprises me as well as the version of that we use is single insulated and we cannot use it clipped to buildingsreplace the cable with 4 twisted singles (that's actually what comes from the pole to the buiding at present), not straight con, which rather surprised me.
I might get my neighbour to 'ban' it on his wall, too!I don't know if I should comment on that, other than to tell you that it is banned by planners in the Lake District National Park!I'm not sure that this liquorice-like stuff
Odd. This chap seemed to generally be very clued up, and said that he'd been doing the job for 30 years, so I wonder if they perhaps have a double-insulated version for clipping to buildings?Never seen it attached to a building, as said being single insulated and not designed to be clipped.
It has only been around for 5 or 6 years at a guesstimate.
I'm at a disadvantage here, because I'm not familiar with the various cables or what they are called.This ABC cable (aerial bunched conductors) is designed, as the name suggests, to be strung between poles in place of the bare overhead lines. It has only been around for 5 or 6 years at a guesstimate.
It can be done as there is an outer sleeve available that slips over the singles. I'm still not convinced about the aesthetics of it. (ABC = Aerial Bundled Conductor)
He appeared to be saying that I ('my electrician') could simply use the DNO's neutral block as a PME earth. Quite apart from the fact that, for whatever reason, that (separate) neutral block has a DNO seal on it, this seemed a rather odd thing for him to suggest. "Discuss"He also told me (showed me on his laptop) that the supply is PMEd, with the nearest PME earth stake at the pole providing my supply,and suggested that I could therefore use their neutral as a TN-C-S/PME earth if I wanted - that certainly surprised me (not that I would want to do that - I'm quite happy with my TT electrode!).
