That pre-plumber pump which you refer to as a boost pump is designed to run the whole system and not just the cylinder (sorry if you know this already, maybe i'm not getting you) I think the problem will be something to do with having two pumps. I've never seen a system with two pumps in series at different points in the system, without a low-loss header. Hmm i'm not sure what the consequences of that would be. Maybe i'm way off the mark, maybe Tony could clarify this???
From the distances you describe I would say the flow pipe from the boiler should be in 28mm and go straight into each of the zone valves, and not via another pump (return 28mm too)
It sounds to me like the system has been poorly spec'd in the first place. Any plumber worth his salt would never have fitted a pre-plumbed cylinder with a system boiler.
Some photos would be handy if you can get some?
