I have just inspected a jammed SERVOWARM manual diverter valve, which is jammed in the open position, so that hot water and central heating are both working.
These valves, I think, are obsolete. Or can you still get them ?
Perhaps I could simulate hot water only, by inserting a full bore lever valve in the central heating feed near the diverter.
Would this work. I think closing off the central heating pipework this way is probably the same job the diverter valve would do if it was working properly.
There are three pipes going into the jammed valve, one is 15mm and the other two are 22mm.
Which one is the central heating feed
