SIME FRIENDLY FORMAT 100 PCB PROBLEM
12 Feb 2007
Middlesbrough
Hello,
It appears that my Sime Friendly format 100 boiler has a temperamental PCB. The boiler will not always ignite and often cuts out, however if I turn the power off and switch it back on sometimes it will fire up. This is mainly when set to Central heating, although sometimes on hot water. I can hear what appears to be arcing and strange noises from the PCB
The diaphragm was changed last month. .
Presuming it is the PCB Can anyone please advise where to obtain the cheapest replacement.
Part number SIME Code 0.503.602 its a blue box another number is 6210203
also on the box is CE PIN 0063AS4787
Many Thanks
hi there m8,my pcb went on my sime friendly 80 and have just purchased one from ebay brand new for £60,it is the same part number as yours was told by a corgi reg gas fitter that this was cheap so hear is the item number for ebay:Item number: 280126376873 hope this helps regards paul
