sime super 80 mk 11
19 Nov 2005
my sime super 80- mk11 keep turning off if its left off for a few hours it will come back on but when trying it after it goes off it dont fire up, preessure overheating what u think thnx
Could you try to explain the problem a little more clearly please and then we might be able to help you. Include the reading on the pressure gauge!
Tony
sime super 90- mk11 information.
Pressure Guage reads 1.5 bar (just over the dark blue bar).
Temp = just over 0 degrees celcius.
Followed procedure from manual.
Open D.H.W valve (vertical), set switch to SUMMER, open D.H.W taps full, Turn on electricity supply, Turn switch to FLAME and back to SUMMER.
Goes through the motions according to the manual, but does not fire up.
Could it be the ignition electrode or something like that.
Had the SIME Super 90 MK2 for 5 Years. Recently had Heat exchange, expansion tank and safety valve replaced at xmas. Worked great for a while but now recurring problem is annoying.
I would appreciate any help or advice you can provide.
Thanks again for your help.
does the boiler make any noise like its trying to fire?? Is it the same for heating? are any lights displayed whiles faulting?
Does it work on central heating or neither?
As a matter of interest why are you asking here rather than calling British Gas or your local CORGI registered heating engineer?
Tony
Bearing in mind that I cant see your boiler and don't have much info about what's going wrong.
A common fault on these is that the ignition PCB goes. It's a blue , sometimes red box on the side of your gas valve. Dont even think about replacing it yourself as it is often the fan which takes it out, [other parts can do it too] I did find one where the APS leads touched against the combustion chamber and melted causing a short. The parts are expensive so its time to crack open your piggy banks.
Nothing wrong with asking about it, but at least you now have a clue as to why Tony suggested you get a specialist in
