hi guys
can anyone put their finger on this for me ?????
new heater and thermal cut out fitted as it was not heating the water up. that all went well but when i came to test it, it all went pear shaped
although i cant be certain if it wasn't doing the following before i got there.
power on, set cycle, shut door then it will go into drain mode 3 times then throw up error 6. no drain apparently !!! poured a bucket of water in the sump and it does drain.
sump float switch seems ok.
not sure about the pressure switch ???
could this cause my symptoms ??
i also cant seem to do the reset everyone seems to recommend by pressing the mode button 4 times withing 3 seconds. does this indicate a pcb fault ????
heeeeellllpppppp !!!!!!
