Part M says between 450mm and 1200mm from finished floor level to be accessible for disabled folk, also sockets and switches should contrast with the wall colour to enable partially sighted folks to see where they are with ease
Well I never knew that.. ?? So your saying you shouldnt use white fittings on a magnolia painted wall? It rediculous the amount of rules they bring in such as this..
I'd be delighted to read a rational argument from you justifying why disabled people should have their choice of housing stock restricted in order that you should not have to encounter rules which you consider ridiculous.
The actual building regs. don't stipulate any specific height. It's the guidance notes in the Approved Document which state that placing them between the listed heights would, in the Secretary of State's view, result in compliance. That doesn't necessarily mean that placing them outside that range would not.
But if this is a dwelling, and is a rewire or extension of a existing building, part M doesn't apply anyway.
The part about a contrasting color can be found in the Approved Document in the section for buildings other than dwellings, so isn't relevant to residential work.
The document also suggests different heights for switches and sockets in non-dwellings - See page 48.
