- Joined
- 28 Dec 2006
- Messages
- 13
- Reaction score
- 0
- Country
Not long moved in and built a gym in garage. Ran 30 metres of 4mm sq T&E to a weather proof Mini CU. The connection to the main CU is with a double pole 63amp RCD. and the live in on the mini CU is a 63amp MCBO. There are two feeds off this - 1st is a 40amp mcb feeding a sauna the second is a 20 amp feeding two double sockets with a 1.5kw spa plugged in.
With the sauna not plugged in or any other appliances as soon as I plug the spa in - the breaker trips.
However if I connect the spa via an extension lead from a socket in the house the spa works fine.
Is the cable too long, are the breakers the wrong size - what can I do - please help
Lifes too bloody short
