Mod Rupert said:
Plse check //www.diynot.com/forums/viewtopic.php?t=19448
Mod Rupert
Erm, who are you asking to check the rules? And why?
BTW, I would prefer it if you didn't just shove text into the middle of my post - for one thing it's hard to spot, and would be much clearer if you would create a new post to follow on, much like everyone else does, and like most other moderators do. Just because you have the power and you
can insert text doesn't mean that it's a good idea.
Mod Rupert said:
If this thread is full of backbiting and name calling, then it has
become a time-wasting post .
Mod Rupert
This thread is
not "full of" those things; it has lucid arguments about the pros and cons of copper and plastic.
Agile said:
I have been called to repair many leaking plastic fittings.
Right then - let's get down to it and get some facts...
How many times, roughly, have you seen a plastic fitting leak?
And how many times have you seen a brass compression joint leak?
And how many times have you seen plastic pipe leak?
And how many times have you seen copper tube corrode?
Copper is economical and pretty long lasting too.
Copper certainly has hygiene benefits, of which you appear to be unaware, but it's not much cheaper than plastic pipe.
Copper is not eaten by vermin
Well then, do what I do, and use copper where there's a risk of vermin.
This is what I mean by using the materials that best fit the circumstances - plastic isn't always the best, and nor is copper.
...and will withstand heating system fault conditions unlike plastic which fails at 1 Bar
Have you seen plastic fail at 1 bar?
Have you seen plastic fail at 130°C? If so, was it wrongly installed, or was there a system fault leading to over-temperature?
People cannot have "private" names.
Yes they can.
You choose to keep it hidden on this forum
It's not hidden; it's just not published. There's a difference. For example, if you wander into a random newsagent and buy a paper, they don't know your name - not because it's hidden but because you don't tell them (or most people don't
...presumably because its better when you are rude to others.
How is it better?
As I am not rude I dont need to !
You
are rude (if you would like examples I can easily provide them), so you're either lying or misguided.
ollski said:
I love change and understand how to use plastic and pushfit, but still prefer copper in the majority of situations.....is that relevant?
Of course. It would be interesting to hear how you choose when to use copper and when to use plastic. Also when to use compression, and solder, and pushfit, and crimped.
Slogger said:
i agree with agile on the copper theme
Easily said, but what exactly do you agree with? That copper is always best? How about when threading through holes in joists - is it best then?
Slogger said:
and yes a school kid could fit the plastic a lot easier than copper regardless]
You say that, but do you mean pushfit? After all, you can use plastic pipe with compression fittings.
So how many schoolkids have you heard of installing pushfit without any leaks ever?
kevplumb said:
the stuff is s***te end of story
Welcome kev - do you mean that it's sh*te?
