spur from washing machine isolation switch??
bmm
15 Jul 2006
Essex
hi all can anyone help me with some advice . im looking to fit a double socket in my consevatorie i was intending to spur from an existing socket.but having looked at possible sockets im unsure wether or not it,ll be the most practical off ways and was wondering if i could spur from my washing machine isolation switch. thanks
Is youR isolation switch wired as a spur or is it wired on the ring.
RMS
it look as if its part of the ring .only 2 cables at back
You will have to prove that this is in fact a ring final circuit by testing end-end continuity between all conductors.
If this is a ring final circuit then you can spur one double socket from this point. Also if the socket in the conservatory is intended to ever supply outdoor equiptment then it will have to be RCD protected as per BS7671.
rms
when i go to my circuit breaker in front room i can flip the switch to isolate all plugs lights etc independently up and down stairs . i notice a seperate switch for kitchein machines ie washing machine fridge freezer etc each object has a seperate isolation switch in kitchein which can be isolted independently so my naivety is presuming this is a ring circuit ? :confused: or at least should be ok to spur from as im presuming it,ll be the same circuit as my sockets???
