Stainless steel cylinder
20 Apr 2007
Cornwall
I am looking for a 400mm diameter stainless steel cylinder without insulation. I am short on space so a 350mm with insulation will do the job. Capacity is not important but size is. Can anyone help with sourcing this.
TIA
Cannot change to combi, no gas, heating comes from oil fired range cooker/boiler. The new cylinder is an addition as the main cylinder is a long distance from the kitchen.
Oil mounted wall combi.
External combi
If this is only to supply hot water to the kitchen. Under counter sealed
system about 10-15 litres. Electric.
Sorted.
What ever you do, dont change to a heap of rubbish like an oil fired combi.
Any cylinder manufacturer will knock you up a cylinder to your spec.
Thanks Norcon, someone with same ideas. Info useful, will try some manutactures.
