Hi, I've read through alot of threads regarding this subject but I'm still unsure.
1. Bathroom- Has a rad, sink, bath and thermostatic shower all fed by copper pipes that have a number of plastic push fit connectors. How should these pipes be bonded in this case?
Should I connect all of the above pipes with each other ie. the rad incoming and outgoing, hold & cold for sink, bath & shower?
Also I’ve been told that the metal legs of my fibre glass bath need to be bonded. Is this the case?
Should the radiator itself be bonded or is it the pipes that feed the rad that should be bonded? I've seen some clamps for sale that clamp directly to the rad.
I've read that the bonding should be connected to the cpc of circuits supplying that room. The only electricity in the bath room is the lighting which are SELV downlighters switched by a pull cord. Should the bonding cable be terminated inside the pullcord switch?
2. Do rads in other rooms in the house need to be bonded. ie living room? If so would you connect to the earth in a socket?
Hope I haven't asked too much in one go. Any assistance is appreciated
