here you go http://www.ebay.co.uk/itm/115mm-Ang...r-wood-and-plastic-40-TCT-Teeth-/271843416314I wouldn't think any saw blades are actually made for angle grinders.
I've got visions of a DIYer holding a piece of 4x2 in his left hand and that grinder with the saw blade in his right. Approaches the timber too fast, grinder kicks back and the blade traveling at 100 revs per second, comes back down on his hand and slices his hand off. It shouldn't be legal, and I doubt it is.
That's just someone on ebay writing something.here you go http://www.ebay.co.uk/itm/115mm-Ang...r-wood-and-plastic-40-TCT-Teeth-/271843416314I wouldn't think any saw blades are actually made for angle grinders.
Then he is not using the tool properly is he.... He could just as easily be holding a chain saw or a circular saw and get exactly the same result
Fact is if you use a properly designed blade for the grinder and for the purpose that the blade was intended and follow the simple safety steps that come with the tools then you will be ok.
It no different from using a super thin steel cutting disc and using it to grind out compo for lead and not expecting Bad **** to happen lol
They are legal the fact that Screwfix does not sell them is irrelevantNow show us one from Screwfix or Toolstation. (he won't). Not legal.
Try brushing your hand across that blade and see what happens. Not legal. Only an idiot would sell one - let alone buy one.
This is one of those times that I agree with you joe.......PS. Don't tell the lads!!!!!!!
