I will be installing a couple of runs of cable (some twin core and earth and some flex) under a patio area. Can a 20mm rigid plastic conduit be used to encase the cables? Is this a satisfactory (and cheaper) alternative to using SWA?
Nope, it will come out of the wall, down behind the render, under the paving, up another wall (400 mm above ground level) and into a socket.Are there any areas where it will not be under the concrete ?
My thinking is that when the patio gets replaced one day, the plastic conduit will be immediately obvious, especially when combined with a warning tape covering it.What happens if one of the slabs gets damaged and needs to be replaced or the patio gets removed?
I know it's not the answer you want to hear but SWA (or pyro or earthed steel conduit) is the only way to do this job properly, safely and in compliance with wiring regulations.
Is the cable behind the rendering going to be within a prescribed safe zone?
Thanks bud, so as I'm burying to 50mm from the finished wall surface, I am in the safe zone by the looks of things.//www.diynot.com/wiki/electrics:installation_techniques:walls
