If it isn't a flush one it would be trivial to put your own enclosure next to it, just have a Henley in the meter cabinet (I'm sure they won't mind that), and take an extra set of tails into your enclosure where you can have whatever you like.
Indeed not (even the 'tails' would have been electrically acceptable, and reg-compliant) - but, as I said, the regs (BS7671) do not require the incoming cable to be any larger in CSA than can be protected by the nearby downstream fuse.Wouldn't have to be quite that small...
All true - but, apart from the issue about more satisfactory termination into a Henley, would there be any point in using 10mm² ? (I suppose one thing which occurs is that it would probably be difficult/impossible to find DI 1.5²/2.5mm² singles and, although I'm sure we've all seen it done (and maybe 'done it'!) many times, it's quite/very difficult to find a strictly compliant way to connect T+E to a Henley. I suppose one could use just one core in each of two T+Es!)Anyway - apologies for any confusion - I thought Andy was concerned about not being able to get tails into the switch. Which he can't, if they are more than 10mm², but a 32A switch (which will fit a standard 1G box) will take 10mm² conductors, and give that everything would be contained within the meter cabinet, I don't see a problem with using that size.
How did you plan to get the SWA out?meter cab is flush
I didn't mean use a second meter cabinet, I meant this sort of thing:Even if I wanted 2, it would annoy the meter man lol
True - but I the point (which I think is what was confusing BAS) is that it does provide accessible bits of side (and, more to the point, bottom) walls through which cables can exit!Humm ok. It sticks out a bit further than I remembered (although most of it is in the wall). Buts its not like a bolted on (e.g GAS) one either.
There is an external oval conduit which the supply comes in via.
I could annoy the DNO and use this or install my own conduit or just have the SWA
I wasn't suggesting that you should use the DNO's conduit - apart from 'the obvious', it probably wouldn't get you to 'where you wanted to be', would it?Yeah. I had already worked that out thoughThere is an external oval conduit which the supply comes in via. I could annoy the DNO and use this or install my own conduit or just have the SWA
