B
Big_Spark
As a happy Medium I would say Martindale are well worth consideration...especially as they are owned by Robin.
BR said:as already stated by FWL, the fluke T5 are a great meter for the serious DIY'er and i know many professionals who use them on site in domestic installations. To correct FWL however the T5 is actually a meter. The T3 is the model with range indication. Another handy feature of the T5 is the 'open jaw' current clamp. For the price this is good.
It only has three features, Volts (auto ranging which will also pick up whether you are measuring ac or dc voltage)
Amps
and continuity/resistance. The only fault i could find with it is that the test leads have to be ordered specially if damaged. Fused probes do not come as standard by can be fitted in place of the ones that come with it.
Also the live probe fitting into the head of the meter (it can be removed if you so wish) provides the '3rd hand’, which is very useful on ceiling roses for example.
What autoranging means is that the day you forget that you last used it on a resistance setting to check a fuse, or set to 2V DC to check a battery, and then you stick the probes into a ring main socket, it doesn't go
B A N G ! !
