Hi folks
Any advice much appreciated.
One of the two toilets in my house wasn't working properly - when flushing the water was either almost draining from the pan completely or backing up and not flushing the paper away at all.
So, having worked out there's nothing wrong with the pan, I've removed the pan in the belief there's a blockage in the soil pipe.
I was going to use drain rods but the pipe drops about a meter before bending and the rods won't make it around the bend. Have also tried jetting the water. Would also try coming at the blockage from the other way but the pipes are too long from the only area I have access. Have checked the drain in my driveway where this pipe eventually leads and that's all clear and the other toilet, bath and sinks in the house seem to be working fine.
One question I have is this: when I look down the waste pipe I can see water. The water is right where the pipe bends, so about a meter down.
Does this definitely suggest there is at least a partial blockage as I thought under normal circumstances, with everything draining as it should, there wouldn't be any water in this pipe. Is this right?
Any other advice would be great. Happy to call a plumber in if need be but always try to do jobs like these myself first if I can. Thinking of maybe trying chemicals next but if it's an object down there they ain't going to work and if it's a partial blockage then I'm thinking the chemicals will just run past whatever's there.
Ben
Ben
