yeah the link is in i wired from connection 1 on the boiler in sl in & conection 2 to sl outhave you got the link in the stat between LIve and the centre of the 3 top connections. the stat NEEDS a seperate live and neutral feed. No earth .
live on the stat is the one with the link in in the middle thanks for your help again.Right, you need 5 core flex, Boiler live to live of stat, boiler neutral to neutral of stat, 1 to sl, 2 to sl out, leave link in stat from Live to centre connection on top row.
i got it now took a while but i got it thanks againFinal time i hope, your stat has 3 connections acroos the top, 2 at the bottom.
Bottom row, neutral from boiler into neutral on stat. Live from boiler into live on bottom row of stat.(this has a link in also that goes to the centre terminal on top row).
Boiler connection for the thermostat now go into the 2 remaining free terminals on the top row of the stat.
Lee
is sl 1 the same as sl in & sl out the same as sl 2i got it now took a while but i got it thanks againFinal time i hope, your stat has 3 connections acroos the top, 2 at the bottom.
Lee
thanks againthere are only 2 connections on your stat and 2 on the boiler it shouldn't matter which way round they go in your case.
