Hello, I have the above shower which has only been on the wall about 3 weeks, but sat in the box a lot longer. After installing it and wiring it up (6mm cable and 30a fuse, short drop to shower) it worked fine, but then 3 uses later it started to trip the electric. After checking all the connections everything was wired correctly and tight, so nothing loose. We figured it might be the fuse in the electric box downstairs and it only being 30, so increased to 32 in case the power it was drawing was fluctuating at times. But no the same next time, and it tripped again. Went through the same process, but this time used a 40 instead so it had ample power - but nothing, the power will not switch on. It's lifeless. I don't want to believe its dead - its brand new!
Anyone any ideas at a last attempt to save it? I'd take it back or do a warrenty effort but the receipt has gone awol
If it is dead, what could have killed it? Because everthing electrical wise seems fine and when it did work, it worked perfectly.
