Underfloor Treatment
23 May 2011
Invernesshire
I'm looking into ways to sort out a smelly / musky problem I have in my house which comes from the damp earth solum under my house. The first thing I am doing is installing more air bricks to help the situation, but I'm not convinced that this will be enough.
I've attached a detail showing the existing situation and how I'm proposing to seal the underfloor, which I'm proposing in conjunction with more air bricks. My main concern is the bricks I am proposing to paint with bitumen are damp because they are below ground. Will the bitumen seal the water in the brick and cause long term problems?
Also, one of my floorboards has just been punctured by the bed post, will this deterioration be caused by dry rot? If so what can I do?
thanks,
  • HOUYSE DETAIL.pdf
First thing to do is get the boards up and then post some pics - could be rot or woodworm
thanks,
Do the air bricks and investigate the rot first.
That may be enough and it is a lot of hassle to lift all the boards...
is the flooring boards (planks of wood) or is it chipboard?
Probe the rest of the floor with a flat-ended screwdriver (nothing with a round point as the marks will look like wormholes) and see if you can make it sink in.
In you sketch, the air bricks ventilate the room and not the woodwork or the solum. They need a DFA (Different Flipping Arrangement).
Frank
