After a more detailed look, it does appear to me that the kitchen is custom made to fit so there would be no way of telling how the cabinets would come apart, if this is the case. I wouldn't be surprised if the entire kitchen's cabinets are made of ply/MDF with a decorative frontage added once they were in place. Also, the hinges appear to be just small butt hinges and not the standard euro cabinet hinges that would come with 'off the shelf' units.
When you look at the pictures that show open doors, you can see that there appears to be a face frame added to the fronts of the 'carcasses'. If this has to be removed in order to take out the units, you are likely to cause even more damage than I first anticipated. Some of the fluting and beading detail around the frames looks a bit uneven (might just be my eyes) which also points to the facing being made out of pine/MDF, routed and then attached to the cabinets. The T&G detail might be a single panel of MDF glued to the back of several units, or even individual pieces.
Personally, I'd avoid this one and look for one that has standard units, for which accessories and hardware are readily available.
