hi i have a valiant thermocompact boiler with arinston presure hot water cylinder my boiler keeps on running when timer says its off and it fires up for 5 seconds and goes off i have pressed th i button and comes up with s7 code then s3 and s4 it is very confusing any help please
Hi, not sure if you're still around, but I have the same problem, but when I turned the temparature to the highest, it stayed on ok. Does that make any difference to the problem/solution?
Also if fault is still apparent press the 'i' button and post what display reads as it goes through this process. It should start at S10 - S11 - S13 then S14 in that order if all is ok.
Yet to have one go faulty on a properly installed installation. But then there is always a first time.
