Hello, wondered if anyone has any experience or tips. Boiler working fine for 18 months until 2 days ago (quite chilly here atm!), it will now happily produce hot water but the heating will just not turn on. The boiler seems to think it's producing heat, but is not firing, it thinks its in central heating mode - the radiator light it on, the pump appears to be making a noise like it's on (internal pump indicator on), but it's not burning gas.
Status wise it thinks S. 0 - no heat required? When I the hot water goes on, the heating will cut in for 10secs or so afterwards until it enters anti-cycling mode and then reverts back to this "thinking I'm on when I'm not" mode. It sometimes seems to go to S. 7 - pump overrun?
I'm going to get someone out (you can tell I have no idea about these things) but seeing as it's -8degrees and saturday, if there's an easy way to turn it on, please let me know before next week!
We have a remote controller for it - that shows the current room temp and that also thinks the boiler is on, shows the flame etc. The green light that indicates the boiler has received this intruction is also on. There seems to be no pressure issue - it's on 1.5bar atm.
Any help appreciated! Thanks.
