Vaillant turbomax
1 Mar 2006
Tyne and Wear
Hi got the vailant turbomax my problem is my raditors are very hot i just dont have any hot water.temp gage reads 90o water pressue is 1 1/2
diverter valve ?
lots of vaillants failing after or about 2yrs ?
HE warranty 5 or 10 yrs ?
yes could be DV, but could also be other problems,
Which type of turbo max is it, ie; vuw uv, or T max plus,?
How old is the boiler?
warrenty on HE is 5 years
On my mum's Vaillent you can set the max CH water temp & the HW temp. It comes up on the lcd display as you rotate the appropriate knob.
check the micro switch on the right side of the diverter valve is making contact. when you open the hot tap.
