customers got a white fronted turbomax and has to keep resetting it mostly on hot water but the water is lovley and warm , central heating works ok but pump and heat xchanger red hot in the day after not being used for four hours ????????
Thanks for the reply you utter **** . I have the gc number but what use would that be to you other than look up the manual ? Cock .. I'm glad I came on here and you two put mr right . When I started to fault find on the appliance I turned it on and it started warming the dishes phew close one
